Hello all I have a on going problem with my vl1500 c90 boulevard 2008 it seems every time I turn around I’m have a issue with my bike clicking and sometimes starts until eventually it leaves me stranded I have put 4 new stators on this bike and I have did the wiring up grade and all along my decomp solinoid has not been hooked up and my bike as it wasn’t hooked up when I bought this bike and at 1st it ran fine for a while off and on with this starting problem; up until now and all I did was install 3” big shots and removed my pairing valve with a g man block out kit then crank the bike took it for a ride and came back home put it up only to find the next morning all I hear is the decomp solinoid clicking and the starter won’t enguage, new starter by the way, and also when I try to cross over the starter solinoid the starter will engage but will not completely turn the motor over as if it’s kicking back so I pulled the spark plugs and that don’t work either it’s the same thing, this dam bike has me so upset I can’t think straight has anyone ever had this problem because I can’t find that anyone has on the internet, any help would be appreciated thank you. (I also hooked the decomp back up and I have it adjusted correctly)
