1 - 20 of 26 Posts
Hey guys! I got a 2005 C50 for dirt cheap a few months back. A little preventative maintenance, and I had it road worthy! I got a backrest, and a few other odds and ends. The main problem I have with it now is the helmet buffeting I get at highway speeds. I have the stock windshield on, and am looking for advice on solutions to ease the buffeting.
FWIW, I'm 6'2" and pretty lanky.
Lowers that are correctly installed and adjusted will eliminate 95% of your problems with wind...... Most of the buffeting on my bike came from the sides of the windshield and below the handlebars.
There are many versions available. I'm sure other members will come along with brand names and models.... I have no idea where my lowers came from..... they were already installed when I bought the bike as second owner....
Alrighty. I did a search on lowers (Which I should have done in the first place :p ) and I think making my own is the way to go. I just have one question (I swear this is all one question!) . Does the placement matter? Should there be a gap between the windscreen and the lowers, or should it be one solid piece? How far down/ how wide out should they spread? Is there an ideal angle?
JMHO, I have a set of chrome lowers that I bought from a VR member. I'm thinking I might just have to install and adjust until I find the right spot for them. Placement probably depends on many factors unique to each bike, including the size of the windshield. I'm sure a more knowledgeable member will have a better answer.
Follow the lines from the front of your tank. Without the lowers you'll find that the wind falls off the bottom of the windshield right onto the front of the tank and compounds the wind flow up into your face. Without the windshield the wind coming from the tank is naturally blown straight back but with the windshield a vacuum is formed behind it compounding the turbulence you feel as buffeting.
The solution is to redirect the air flowing off the bottom of the screen onto the lowers and down away from the front of the tank.
Which lowers you use is just a personal choice. Placement is dictated by the above principals.
Lowers need to extend about 2" min up behind the windshield
I have the home-made lowers that bolt onto the windshield bracket. This was one of the first and best mod's I did to the bike to prevent buffeting.
for me it was to get the windshield up high enough for me to look through it
My preferred sitting position with respect to the windshield is to be where I look just over the top to see a ''mile'' down the road and where I looking through the top inch to ''look through the turn'' for good riding practices.....
The windshield, at that position, still shoots the wind up and over my head - the odd bug still gets through to test my helmet though.....
I tried that too but just couldn't get it right for me, the higher I got it the better it was. could never feel the air coming up from the bottom but it was beating the top of my helmet to death, I may lower it and make some homemade lowers and try them just for kicks
Lowers?
Yeah, lowers will stop that annoying buffeting. When I had the OEM windshield installed, I had the exact same problem. What was worse, it was so bad I continuously had double vision above 50 mph. Turns out the ride height of the windshield is just an inch or two too low for my sitting position. I'm too tall for it.
I went looking for other things to try, experimentation time. I made a set of lowers using 1/8" plexiglas and sized them to reach from approximately 1/2" below the windshield down to about 4 inches above the front axle. For attachment points, I used a pair of polished up aluminum 1" angle, drilled to match the windshield upper mounting bolts (the ones that are roughly parallel to the fork angle).
The difference was amazing.
No more head bobble.
You got me curious. Friday, while I was riding, I was checking the air flow (yes, with my left hand). My windshield is at a height that the air flowed from the to of the windshield to the top of my helmet. (I have lowers, courtesy of the previous owner.) Wind from the sides was not an issue. I did feel some in the front that I think was coming from the gap between the bottom of the windshield and the top of the gas tank. I have the windshield up as far as it will go, creating a 3-5 inch gap at the bottom. I thought about adjusting the windshield down some if I can but summer time will be here soon and I will want some wind on me. So, I may adjust it late in the fall.
I don't see anyone mentioning the angle of the windshield. That is also a critical issue in determining the air flow.
Is there a way to adjust the tilt of the OEM windshield?
Air over the top hits the top of my helmet and I was thinking if I tilted it so that it sat a little straighter it would be just right.
Sent from Motorcycle.com App
I have VA lowers and they made a huge difference with air coming under the screen. This is coming over the top and catching me just above the visor.
Edit: I'm 5'10" and look over the top of the windshield
You can absolutely change the angle, and it's easy.
This is not a pic of a C50 but the theory is the same. Take out the top bracket bolt on both left and right sides so you can tilt the shield forward - put the bolt back in behind the bracket or pinching it as shown in this pic. I can't say it made a huge difference on my C50 when I did it, but it made enough difference that I ended up leaving it that way.
Yes you can change the angle, I had my windshield like that but just today I made a set of lowers and put it back at factory angle. All I have to say is the lowers did make a big difference and I will admit to being one of the biggest skeptics on this idea. Can't speak for the store brands but the homemade ones did the trick. I did just a short test ride and have to do just a little tweeking.
1 - 20 of 26 Posts
