1 - 20 of 23 Posts
Hi all;
I just bought my first bike last fall - a 2009 Suzuki C50SE. I love the bike, but I'm still having problems figuring out what gear I should be in and at what speed. The manual suggests:
1st - 2nd @ 20 kph (12 mph),
2nd - 3rd @ 30 kph (19 mph),
3rd - 4th @ 40 kph (25 mph), and
4th - 5th @ 50 kph (31 mph).
I've tried this, and the motor seems to labour because I'm in too high a gear at too low a speed. But the bike is happy cruising around the town in 3rd when the manual says I should be in 5th.
I don't want to overwork the motor for being in too low a gear at too high a speed, but without a tach I can't tell what the engine is doing.
Any suggestions or opinions would be welcome.
Thanks.
Mike
I tend to agree about winding it out. It is not a sport bike but I tend to shift in the higher rpm range. Ride it like you own it. And like you mentioned I find myself in third in town majority of the time. You will really begin to hear the bike once you forget concerns on reving it too high, which you can not with the rev limiter anyways.
Just side note I do not really notice a real difference in mileage letting the bike wind up a bit.
Because of the way suzuki tunes this bike it has great low end torque. Lugging any engine will beat the rod and main bearings out of it. More rpms means more oil pressure and more oil pressure means that metal parts will remain suspended in oil.
Something I realized recently. I started wearing ear plugs again. With the wind noise kept to a low level I can hear/feel the engine working. When the engine first begins to lug I feel it where without earplugs I could not.
I've worn ear plugs in the past and could not detect what I just described. Could it be I'm now @ 10,700 miles (broke in) or the fact that my tires are nearly worn out?
Try the ear plug trick around town and go easy on the throttle at first.
When I first got into riding back in 2004 I read a book "Smooth Riding the Pridmore Way" which offered a take on his style of riding basicily rising in higher rpms...while his style seemed geared more toward sport tourers than cruisers I tried his ideas and found the bike responded better using his techniques for the type of riding I usually do which is back country roads 45-60 mph...I will add I did add a tach and found the ranges of rpms that I mostly rode in was in the mid 3's...no that a tach is needed...by feel you will be able to develop a sense when its time to shift according to your style...these engines are not fragile or sensitive...challenge them and let them work to your needs.
Ride it like you stole it. They like to rev. I cruse all day at 80k in 4th with no problems and it will pull to 120k before hitting 5th. Lug it to low and it will stall and you will fall down! Bin there don that.
I REALLY try to keep the motor at around 3000-3500 when I cruise in any gear. My shifting I feel is best around 3500 or upwards of 4500 if I am in a hurry. I do have a tach and it does help. Also have a Modded rear drive.
I can cruise in 5th down to 2000 but tend to NOT do that as it can lug if you accellerate and is sluggish.
If you keep your shifting above 3000 at least you will be OK..
Cheers
Discussion Starter #14
Change the KPH numbers to MPH and that would be a more realistic view.
When I do that I get:
1st - 2nd @ 32 kph (20 mph),
2nd - 3rd @ 48 kph (30 mph),
3rd - 4th @ 64 kph, (40 mph) and
4th - 5th @ 80 kph (50 mph).
These seem like much better numbers for shifting to me.
Good to know I can't over rev the engine - when I was first learning to drive I accidentally damaged my mom's car engine by red-lining it. Luckily it was only minor damage, but I've been a little sensitive about doing that ever since.
My rule about shifting, there ain't no rule about shifting except don't lug the engine. My shift points will change with the conditions I'm driving in. Stop and go in traffic gets a different shift point than hitting an entrance ramp on the highway or pulling away from a light next to some young guy trying to impress his girl.
Yeah, I know 62 year old men are supposed to be beyond that sort of thing. Go figure.
Redlining these motors is unlikely as they sound like a freaking jet engine. You can hear they are labouring. Not like a sport bike motor. at 6000 it sounds like its gonna fly a piston at my crotch. No need for those RPM's on a motor designed for low end torque! in fact you will lose power up that high compared to shifting where the motor is making power generally I feel under 5k. They just are not ported nor breath nearly well enough to develope effective power at high RPM's
Cheers
Green values are speedometer speeds I have Used on my 2007 C50. Values shown are approximate and are mathematically calculated not speedometer speeds. Hope you guys like me without a Tack find this useful.
The C50 likes to be revved and it has a computer RPM limiter. It can however be overreved by shifting down at too high a speed. But the bike has no way to prevent engine damage from lugging which comes from loading the bike too hard at low RPM. If riding two up let the bike rev a little more than normal it will thank you.:wayhappy: If I am crusing near the bottom of a gears range I generally will downshift to accelerate rather than just twist the throttle.
And I agree the book shifting speeds are way too low. Closer to the minimum speed to be used for shifting to the next gear.
Depending on the speed i'm trying to get to, I'm usually in 5th only if over 45mph. On the group ride today, i found it best to gun it, shift when i felt the torque start to diminish, then keep hitting the heel shifter 2-3 times looking for 6th and 7th gear LOL Excluding deceleration, i'm either in 3rd or 5th a majority of the time. Sometimes 4th if it's a 35mph road and i'm just bobbing along
I'm always torn between first and second gear when I'm driving at slow speeds, like in a parking lot. What's the maximum speed at which you can downshift into first, without damage or excessive wear?
your bike will tell you, first tends to be stubborn to engage until you get close to 10mph (without matching engine to road speed for 1st). In a parking lot just lump around in first, with all of the idiots in cages out there and people that don't GAF about what's going on around them you want to be moving slow anyway. Besides 1st minimizes the possibility of stalling out and allows rapid deceleration without touching the brakes. On the road in light traffic 2nd, heavy traffic and/or frequent stops keep it in 1st. No point popping up into second just to have to pop back to first and stop half a block later.
1 - 20 of 23 Posts
