1 - 12 of 12 Posts
I have found that it's probably not a good idea to leave them plugged in! :nono:
My bike has been sitting for about a week and a half and she was a no go last evening :?
I had no device attached but I guess the L E D plus what ever is going on inside the charger, still has enough draw to cause trouble.
The USB charger will pull a constant 5v dc at whatever current it is rated for. That can kill your battery in a matter of days. I put mine on a switched circuit to protect the battery.
What were you riding when David flung that rock at you?
There you go hi-jackin" my threads again!!:wink2:
It's nice to be able to charge something like your scala while stopped for lunch. Either way you hook it up, I guess some new habits would have to be formed.
I'm trying to get the timing right here. You usually don't start 2 threads at 1 time. How many bikes do you ride currently?
Only the Valkyrie :scoot: ...... I guess that's one .... 1.
How's married life?
Absolutely wonderful!!! Yeah me! :applause:
Thanks for asking.
In regards to the USB, survey says: if you don't feel like using it don't stick it in :p
Agreed....go figure! :biglaugh:
What is just as likely is that your battery is weak and may need to be replaced. You should check the battery voltage next time before you start it up. I won’t go into the voltage details here. You can find that info online.
I leave mine plugged in, however bike is on a trickle charger that's on a timer each day for 4 hours. You shouldn't have to worry about it i.e. when you stop for a few hours, if your battery is that weak it's gonna leave you stranded soon regardless.
Discussion Starter #12
I believe my battery recovered.
Sent from my STV100-3 using Tapatalk
1 - 12 of 12 Posts
