1 - 20 of 25 Posts
so I found what I want to do with my stock header pipes.. I found both of these and would like to try an upswept exhaust on my '01 Volusia. itll save me from havin to spend $300+ on drag pipes, and give the bike my own little look. the only thing im worried about is the diameter of the adapters. anyone think they wont work on the end of my header pipes?
Discussion Starter #2
so I got the parts ordered, along with a K&N air filter. after I have my tires and rear brakes put on, I should have my pipes here and ready to throw on. then ill get the bike rejetted. im thinkin a stage 2. ill keep everybody posted
Look up Garmck on this forum or Black op Bobbers to check out what he did with his pipes. I'm sure he can offer advise.
I don't wanna go with an angle that close to vertical. I just want a slight upswept-ness.. his pipes do look good though. just not quite my style
Mock Up/Need Ideas
So the UPS guy showed up with my pipes today. Anxious, I immediately went to work doin mock up. As seen in the pictures, I got the pipes semi-mocked up. But I need ideas for how to plug/block the equalizer hole on the top pipe. If at all possible, how could I block it without simply cutting it off and weldin a piece of sheet metal in it's place?
Hit the hardware store and purchase a pipe cap, slide it inside the equalizer tube with some exhaust putty then clamp it...the stock clamp and chrome cover will still fit....which will also help conceal the tube so a win win.
is there any chance of the cap popping out at higher RPMs or when I hit the throttle?
No, Ran mine like that when I was runnin short turnouts, never had a problem....i cheated though...plugged a socket with metal putty, stuffed it in and clamped it down.
Discussion Starter #10
im thinking about cutting the equalizer pipe off the stock lower muffler, stitch/spot welding a small piece (about the size of a quarter) over one end, then clamp the "plug" into the pipe. That way, I don't have to spend much money, and I can always cut the welds, and put the stock mufflers back on if I ever need to.
Discussion Starter #12
hmmm, good point. I didn't really think it through I guess. Thatll save my stock mufflers too, instead of choppin them up
Discussion Starter #13
dfinitlydisturbd, quick question.....
what size socket did you use? I have a bunch of older chinese and taiwan made sockets sittin around, and could use one of those (since its an asian bike anyway :biglaugh:). Thatd actually save me that $5, and I could still save my mufflers. Im all about saving money when I can!
Good question! Don't know off hand, it was an odd size spark plug socket (have a large collection, every engine I get seems to need it's own size plug socket), and needed a few "taps" with a hammer to get it in....didn't hurt the pipe though sealed and fit fine when I put the stock pipes back on.
Easiest, well quickest way to determine size would be to throw a tape on the opening and measure it.
Discussion Starter #15
well I gotta take a 350mi round-trip ride to Norman, OK next weekend to visit my dad. My Dynojet kit wont be in by then, so ill have to run my stock pipes to ride down there.. And the weekend after that, I move back to college. So it may be alittle while before these pipes get done.
You don't need to rejet if all you are doing is the pipes. The intake is what requires a rejet. Since you are using the stock headpipes there is a lot of restriction built into them by the fact that they are such a small diameter. Aftermarket pipes are a lot larger the whole way through. With no change in the volume of air entering the engine, there will be little to no change in the amount of air exiting through the pipes. It will just be louder...
Discussion Starter #17
Im not tryin to start an argument.. But my bike was running lean when I got it, stock. From what ive read, almost all the Volusias rolled outta the factory running lean for emissions.. I did the Honest Abe's modification to the stock mufflers, only I opened them up alittle more. That made it run even more lean, and it pops real bad on deccel. The new "mufflers" don't have any restriction. I also have a K&N high flow filter thatll be added to it. So the 150 or 155 should work for me.
Discussion Starter #18 (Edited)
I found an old 13/16'' impact socket in a box in the shed. Ground it down far enough to put it in the equalizer pipe. Ill fill it with a bead with the MIG welder, or maybe some JB weld. After my trip to Oklahoma next weekend, ill put the "plug" in, and finish up the exhaust.
Discussion Starter #19 (Edited)
So the upswept idea totally backfired. Its pissed me off to the point where I said to hell with the upswept tips. Im just going to put the turn out mufflers onto the stock header pipes, like the bike in this video- https://www.youtube.com/watch?v=PrxzF5ZJJck
The problem is, the mock up worked great. But now that I start welding and tightened stuff, NOTHING lines up and it looks like a 6 yr old put the pipes on. And with the shields over the header pipes in the way, theres dang near no way to weld the pipes and adapters together while theyre on the bike.
i was thinking of doing about the same thing to mine. was watching some different rear headers on ebay so i can cut and patch in the down tube and keep my original if anything goes bad. my question is what is the size of the pipe coming out of that header pipe that you would attach them mufflers too? i am wondering so i can try to get everything i need before i attack this project. if anyone can let me know that would be great
1 - 20 of 25 Posts
