I am thinking of buying a C90 ignition switch and relocating the switch to the right hand cover. Has anyone tried this?
Interesting concept, wires from the neck would have to be extended to the new location. I wonder if the plugs and pin locations are compatible between the two? Might be as simple and compatible as Dan Hillis was with his DJ Drive initiative.
Discussion Starter · #3 ·
looking @ yesNokeys and it looks rather simple. I think that I can use the same hole on the neck cover to place the start button. We'll see.
The C90 or VL1500 will not work because there are only 4 wires to the harness and the C50 or VL800 has 6. Also, you wont have the handlebar lock.
HTH
BB
I know it would cost a pretty penny but why not get a new switch and then some pig tails. then you can take your time and wiring it up just by extending stuff. Really thinking about this.
