1 - 10 of 10 Posts
I have a 2006 c50 and am trying to figure out if my swingarm is bent or is it the frame. There is a half inch difference between the frame dimensions and the swingarm dimensions where the bearings mount to the frame does anyone know what the dimensions should measure so I can check my bike
First post needs a hearty welcome....Hearty welcome from the Burg.
Not sure I understand the question, but one thing I can tell you is that the swingarm on the driveshaft side is fake, and has no meaning to anything.
My swingarm at the bearings measure 10 inches across outside to outside my inside frame opening is 10.5 inches try to figure out if my swingarm is bent in or is my. Frame bent
Stupid question maybe, but why all of a sudden is this a concern?
I'm putting the bike together from parts I had a used swigarm and frame when bolting the swingarm on the pivot bolt goes in to far to put the jam nut on the right side the gap is to large between the swingarm and frame before I trying to see if the problem is the swingarm before I order another one
Try posting some pics so we can see the problem.
1 - 10 of 10 Posts
