Hey guys I a C50 here that is backfiring like crazy and is extremely loud. She has almost no power under load and looks like she burned up the back cylinder spark plug. The back cylinder exhaust is where you can feel the backfiring even while in neutral. If you twist the throttle back on forth whole riding as you go down you can hear her change and sound better for a split second and get some speed back but then she bogs down again.
I replaced the fuel pump, spark plugs, oil, and air filter.
She is my first bike and I bought her off a guy that didn't treat her right.
Any ideas and help would be greatly appreciated. I miss that wind therapy.
Check the valve clearance. If the valves are within spec, then do a compression check. Anything less than 152psi is considered worn out.
Reactions: ShelbyGT6869
2006 Suzuki Boulevard C50T
Look for a post on the “*******” tool as the oem one isn’t cheap for something your only going to do once or twice,,, valve adjustment
