1 - 14 of 14 Posts
Think my stator went bad. If it is...are the Ricks stators really all that bad? Just don't have the $350+ for OEM one. Any idea if plug on them fits factory without mods?
What bike are you trying to fit a stator to?
$250.00 or less. Metrectric parts outlet. Looked at 2003 Vol. Be sure before you buy.
How have you determined the stator is bad? Can you provide any detail, what year model, C50 or C90?
Have to check when I get home, but battery meter hooked to bike is reading only about 11 volts. Was getting a charging green light until yesterday. Will figure out for sure before I get but, been hearing all the probs with 2006 c90 stators.
I checked with Ricks a few months ago. Their stator is factory spec, so no improvement over the weak stock stator there. I was disappointed.
The OEM for that year was covered under a recall. I would think that new ones, although OEM, would be updated.
Reactions: Gene
Have used ricks stuff in my shop for years, have probably installed 2 dozen of them. It is high quality and good return policy. Make sure that you check your regulator rectifier it is suggested that you change both at the same time. Any good shop can do a charging system check for you for free, well we do
Discussion Starter #10
Well, broke down and ordered stator and rectifier from Ricks. Crossing fingers they work ok. Question is, the sales rep on phone said its possible they may arrive needing to reuse the oem plug. Not too concerned about that as much as hooking the wires up correctly. Doesnt the stator have three yellow wires? Are they somehow marked differently?
Discussion Starter #12
Got rickshaw stator and voltage regulator. Everything came with correct plugs, fit perfectly. Charging at 14.4 volts. Only difficult part were those **** inside rubber grommets, for the r/r cover, kept wanting to fall off when I put on. Is there an easy way to make them stay while putting on?
LocTite, Permatex or 3M weatherstrip adhesive will quickly glue rubber to metal, but the metal and rubber parts must be clean and free of oil.
Give the adhesive about 20-30 minutes to tack the parts, the warmer the air temp, the better.
Weatherstrip adhesive will cure in about 10 minutes or less, if exposed directly to hot Summer Sun.
BTW; LocTite brand is far cheaper, and especially when purchased thru Amazon......a large 5 oz tube will last for a few years, if properly capped and stored. It also secures nuts and bolts, yet they can be easily removed when needed.
Reactions: Rich H
1 - 14 of 14 Posts
