My bike is fuel injected. It’s a 2005 Suzuki boulevard c50t. When I start it up I have to throttle it and warm it up before it will stay ideling and running. If I try to start it up without doing that it just shuts back off. I have no idea what the issue is, but after I throttle it for 5 min it stays going, but if I have to stop for gas and I turn the bike off I have to go through the whole process again.
Add Injector Cleaner to the fuel tank.
Possible fuel injector issue. It is also possible that you have the idle speed turned down too low and it won't stay running until it is good and hot inside the cylinder head. The engine is supposed to idle at ~1100rpm. If it sounds like a Harley, it is too low.
If it sounds like a Harley, it's got way more problems than injectors!:biglaugh:
