Need help to try to determine start button problem or something else. Had to get whole different set keys made to match key cylinder. Everything does normal noises n buzzes when key turns on, blinkers and horn works. Got battery tested and is good. But when key is turned and push start button nothing happens. Need help
Have you tried shooting some electrical contact cleaner on it? My bike had a problem with the start button when I got it. Hosed it down with contact cleaner, let it air out, and haven't had a problem since.
Kickstand switch might be sticky and causing your issue. Almost silly to suggest but double check that the kill switch didn't get bumped. I was riding with my son and he started to slow and pulled over. the bike died. I told him to check the kill switch. somehow he bumped it enough to kill the bike and didn't realize he had done it! A big relief that it was that simple and away we went to enjoy the rest of the days ride.
