As the title says speedometer, odometer, and fuel gauge will stop working, and come back on. Its not all the time, sometimes they come on when i turn on the bike sometimes they don't. No rhyme or reason to it. Does not happen when riding no turning off and on and no jumping of the speedometer needle while riding. everything else in the cluster works. dummy lights, back lighting of lcd and speedometer work fine all the time.
I did search the forum and google. I does not seam to be the speed sensor in the wheel because of the lcd going out as well and when it does work it works great. I pulled the cluster off checked the plug and it seams to be fine. i have read that the wiring is known to rub on the frame on some of the bikes.
I have not yet tried to pull the tank off and take head light out to check wires yet. I wanted ask if there is anywhere i should check in the wiring harness before i go to town on this thing with the voltmeter.
thanks in advance.
thanks in advance.
