I have an '06 C50 and have removed the far rear baffle in each pipe and that's all. Will my motor have a chance of running lean and how can I check it.
Thanks
It will not be any leaner than it was. You only allowed a little more exhaust to flow. You didn't add any more air and/or gas to go in the front side of the engine. It is just louder now.
Ride Safe,
Rex
It will only run leaner if you change your air intake. if you change to a k&n filter or enlarge the opening of your air intake (the hole under the breather).
