I put on 12" bars and I got to tell ya...there is a lot of junk coming down from the grips to the top tree. I am going to route the wires through the bars to hide them. I was looking at just drilling a hole in the bottom of the bars between the risers and bringing the wires in front of the tree and route through the hole. I thought this would look cheese-ball. So, I am going to center-bore the riser bolts on the lathe with a 1/4"-5/16" hole, then drill a hole in the bars above each riser bolt...then you wont see the wires at all...I will post pics of process. There should be no effect on the 1/2"(12mm) bolt, strength wise. I just hope a 1/4" hole through each will accomodate the wires...any thoughts?
Jason
Jason
