Hey guys,
I'm looking to remove the speedo mounted to my tank and put an after market speedo on my bike. then cut and weld a plate into the tank.
the hard part is going to be re wiring new indicator lights as the speedo doesnt have any.
does anyone know what voltage the leds run off or has anyone rewired them and know what leds or lights can be used.
thanks a lot
Discussion Starter · #3 ·
Yeah I was thinking something like that but With LEDs you need to know the voltage and I also need to wire up indicator lights for high beam, FI, neutral etc
I might pull them apart and see if they are LEDs or bulbs
Discussion Starter · #4 ·
Just had a good look at the wiring diagram, the dash lights at least for the indicators run straight off 12v so they must be 12v bulbs not leds
