I noticed one of my lights on my light bar is out, anyone know what bulb that takes? its a national brand
less aggravating than when they blow out again and again and again...nature of the vibration from the bike...4411's are a tractor bulb designed to handle the vibration...takes only a few minutes to do the mod.if it oem, change both to 4411. cheaper. last longer
Are you referring to the ''National Cycle'' light bar like this one...?I noticed one of my lights on my light bar is out, anyone know what bulb that takes? its a national brand
What is "the mod?"less aggravating than when they blow out again and again and again...nature of the vibration from the bike...4411's are a tractor bulb designed to handle the vibration...takes only a few minutes to do the mod.
Go to most auto parts store and ask for a 4411 sealed beam. They were used for tractor lights for years and years. Sealed beam. Small headlight. Full glass enclosed housing. Fits perfectly in the OEM light bar housing. Clip the pigtail off the current replacement bulb socket and wire it up the rear of the 4411. Remove the glass lens from the OEM light and replace with the 4411.What is "the mod?"
Thanks!Go to most auto parts store and ask for a 4411 sealed beam. They were used for tractor lights for years and years. Sealed beam. Small headlight. Full glass enclosed housing. Fits perfectly in the OEM light bar housing. Clip the pigtail off the current replacement bulb socket and wire it up the rear of the 4411. Remove the glass lens from the OEM light and replace with the 4411.
National Cycle Complete Chrome Light Bar- Suzuki C50 Boulevard (05 and newer)/ VL800 Intruder Volusia (01-04)
If so, you'll have to remove the bulb to match up a replacement. Someone else may know a part number and source.
If it is the Suzuki oem bar, you can replace the bulb and lenses with the 4411 as others have already said OR any of the following....
Suzuki part number 99950-70276-006
Honda part number 34901-MN1-671
Yamaha light bar bulb......... ABA-T1912-V3-0S
I believe that the Yamaha and Honda bulbs are less money than the Suzuki ones.....
and the Yami bulbs have lasted longer than the Suzi ones as well...
