1 - 12 of 12 Posts
I just brought home a 2003 anniversary model and I can not figure out how to get the side panel off to get at the tool box and rear suspension. I can turn the key and the bottom will come loose but I’m afraid to just pull on the side panel to get it off. After the key is turned what do I do next?
Thanks!
Lift the bottom end gently and pull the top. If I remember correctly there are a couple of studs at the top that are pushed into a couple of rubber grommets.
Pull it off.... from the bottom..prying a little bit upward.... you should see the 2 studds in upper part....
removal
after unlocking you will need to give it a little tug.
Pull from the bottom right first out and up slightly to get the plastic plug guide to be remove from the rubber grommet (behind, you can not see it). only pull enough to feel it unseat.
Next you will tug left top corner out and slightly up. Only pull enough to unseat. You will then left cover up from the bottom and angle upwards and out.
It is kind of a pain. Do not use too much force.
PULL IT!!
And don't be surprised if it is difficult to put back....
get a bigger hammer
Good place to keep a bag of...........................................
...................................................................................................tools
aceshi21 said:
PULL IT!!
forgot, youll need a sawz-all and about 4 replacement blades.
That stud in rubbers attachment is on the left tool box, right cover, front fork center plastic chrome, neck covers also. Be careful when you pull on it because, as your mother once told you, if you keep pulling, it will fall off.
Yeah, what everyone else says here, tug and be carefull. Don't be suprised if the plastic "stud" breaks off, mine did. The one to the rear which is behind the frame. Put a little lube when going back together for easier disassembly next time.
As stated "it's a pain" and don't get used much!!
1 - 12 of 12 Posts
