Perhaps it is secured with Loctite? Loctite is released using heat.
Again, I am not familiar with this particular application and stud. Hopefully someone more familiar with this item will come along and offer some better advice.
Not sure about this exact application but typically a stud can be removed by using two nuts tightened against each other and then turning the inner nut to remove the stud.
I tried this method, having been successful with it many times in the past...spun off. Tried again with red locktite...spun off. Tried again with JB Weld...spun off. My next attempt will be to lock the nuts again with JB Weld, goop up a socket with JB Weld, put it on, let it set up and try again with the breaker bar.
If you achieve success, please post what worked.
