1 - 20 of 22 Posts
I went to the rusk site and printed out instrutions on removal of stock grips, the only thing not clear to me is when you unscrew the end weights are you supposed to lossen and pull? or take off completly and work on grip?
Thanks :?: :?: :?:
No - loosen and pull the weights out. DO NOT REMOVE THE SCREW COMPLETELY or your will lose the other half of the endweight inside the handle bar.
Once the endweights are out of the bar, you can start working on the grips.
^ What he said!!!!!!!!!! :lol:
Banned
If the screw does come out completey then you might be able to retrieve the expansion bung with the hook end of a bicycle spoke before it slides down too far.
wait....I shoulda asked a question first....are you replacing the grips with different ones that won't use the end weights? or do you need to re use them? Sorry, shoulda asked that before. I totally replaced mine and did not reuse the weights. Hope I didn't screw ya!
Thanks :?: :?: :?:
Hey iceman, I just ordered kury iso grips. Where did you find the grip removal instructions?
I used WD-40 and squirted it in side the grips to loosen the glue.
http://i140.photobucket[IMG]http://i140.photobucket[IMG]http://i140.photobucket[IMG]http://i140.photobucket
If you get a coat hanger and make it look like I did you should get the picture pretty clear as to how to do this. JimmyG
The WD-40 breaks the glue free, it disolves it. Just twirl the coat hanger in your fingers and walk it around the grip inbetween the handle bars and the grips.
1 - 20 of 22 Posts
