What was your original problem for wanting a new motor?
Carbon build-up won't reduce the compression.
If the rings were bad (and causing low compression) you'd get blow-by and lots of oil consumption. You'd notice oil on your air filter or in the air filter housing (if you are using a stock set-up).
The next thing, if you didn't have blow-by but still had low compression would be the valves. Like a burnt valve or bad seating due to wear.
If your cylinders are scored (and they are old skool sleeves, not Nikasil), then a bore to .005 over and over sized pistons are needed. Someone needs to chime in and tell if these are Nikasil or not, I think I read somewhere they are not Nikasil (makes sense since oversized pistons are out there).
