Decided to Rebuild
40,000 miles.
OK....I pulled the heads and jugs off and need to ask a few questions:
1) Both pistons and plugs have a lot of carbon build up. The front far more than the rear. As you can see in the photos, the build-up fills the indentations for the valves completely. The front compression was about 20-25% less than the rear. Can that carbon build-up kill compression and cause the bike to run poorly? It was also blowing a lot of oil out of the air box (but no blue smoke out of the pipes though).
2) The connecting rods have a small amount of left-to-right play in them. Is this normal?
3) When I replace the pistons and rings should I do a valve job at the same time?
4)Being as these cylinder walls are lined, do I just buy the stock pistons? I see that there are .005 oversize pistons for sale.
5) Is there any reason to crack the case? I had both timing chains and tensioners replaced less than a year ago and had virtually no bottom-end noise.
6) For some reason I can't get the alternator cover off. All the bolts are removed, but when I gently pry the case from the motor it seems to "spring" back as if something was still holding it. Any ideas?
7) Is there anything else I should do while I have it out and apart?
As always, thanks to the VR Community for any and all help.
