i just used a hook from a bungee cord.... loladambomb said:it snaps together with about 8 snapes. I wanted to get the spring off, cut a little hole in the leather that would go over that knob and snap it together and put the spring back on.
For real? Did you really just use a bungee cord hook?PhL0aTeR said:i just used a hook from a bungee cord.... loladambomb said:it snaps together with about 8 snapes. I wanted to get the spring off, cut a little hole in the leather that would go over that knob and snap it together and put the spring back on.
Sure, that'll work.. so will an old screwdriver with a 180 degree bend/hook in it.. That is what I use.adambomb said:For real? Did you really just use a bungee cord hook?PhL0aTeR said:i just used a hook from a bungee cord.... loladambomb said:it snaps together with about 8 snapes. I wanted to get the spring off, cut a little hole in the leather that would go over that knob and snap it together and put the spring back on.
yessir.... i might advise some safety eyewear, but it gets em off and puts em back onadambomb said:For real? Did you really just use a bungee cord hook?PhL0aTeR said:i just used a hook from a bungee cord.... loladambomb said:it snaps together with about 8 snapes. I wanted to get the spring off, cut a little hole in the leather that would go over that knob and snap it together and put the spring back on.
that just sounds painful..... loladambomb said:see, what would i do without you guys and gals. Id probably still be trying to pull it off with my hands. :lol:
now THAT is ingenuity.Goldstar225 said:Extend the side stand. With the spring stretched, stick pennies in the open coils then retract the stand. The pennies will keep the spring extended and you should be able to just lift the spring off.
no fear of losing an eye???? niiiiiiiiiiice!!!!wehrd1 said:now THAT is ingenuity.Goldstar225 said:Extend the side stand. With the spring stretched, stick pennies in the open coils then retract the stand. The pennies will keep the spring extended and you should be able to just lift the spring off.
Thats a great idea. Good thing i have been saving my pennies.Goldstar225 said:Extend the side stand. With the spring stretched, stick pennies in the open coils then retract the stand. The pennies will keep the spring extended and you should be able to just lift the spring off.
Pure brillance! Ed... well that's another story.Goldstar225 said:Extend the side stand. With the spring stretched, stick pennies in the open coils then retract the stand. The pennies will keep the spring extended and you should be able to just lift the spring off.
