Rejetting with motorcyclecarb.com kit for stock airbox and V&H Staightshots. Do I have to fool around with the needle side(black cover) of
carb, or Can I just remove the opposite side cover and replace the two
jets , mixture out 2.5 turns and be done?????????????
Thx in advance
Banned
sorry, don't know since i got fi. but, if you put more of the question in the subj line it might help attract an answer?
Discussion Starter · #4 ·
Thx Vol....the kit has one washer in it. I'll try that. I just hope
it's real obvious how to install once I pull the diaphragm etc. apart.
I assume you get an o-ring in the kit in case you lose the original or
just replace it anyway.
joek
joek
Yes, the o-ring is extra and easy to lose. Also when you put the needle back in you should hear/feel a slight "snap" or "pop".
Discussion Starter · #6 ·
Thx again.....
joek
