1 - 2 of 2 Posts
· Registered
When it says to bottom out the adjuster, does that mean to turn it until its fully tight and then back out 1/4 a turn, or do you turn it until you feel a bit of resistance and then back out?
Thanks
· Registered
I did it with a bit of resistance. On the first valve I went back and forth between feeler gauge and JPaige methods to convince myself they were equal. Things go easier when the confidence is there. Good luck with the adjustment.
1 - 2 of 2 Posts
