Hate to admit this, but ...
I've had a Volusia or a C50 since 2004, and never noticed this before - went for a 50 mile ride with my better half, and when I got home, I decided to check the tire pressures. In doing so, I noticed that the rear wheel hub was pretty warm - I didn't want to leave my hand on it for more that a couple of seconds. Both the brake drum and the rear differential were warm. I thought that I had plenty of play in my rear brake linkage, so I don't believe that was a factor. Question: is it normal for the rear hub assembly to get pretty warm, and if not, what are some possible issues?
Thanks for any help!
The brake may have been dragging but it is normal for the final drive to run 50 to 100 degrees above ambient temperatures.
what weight oil does the diff. take ? I have 2 bottles that are different weights and yes I OVERLOOKED that last oil change whooops
I use 80W-90.
Reactions: htlong and Duffy
The hypoid gear generates a fair amount of heat when in use. Completely normal for it to be warm to hot after a ride especially after the additional load of riding 2up. 75-90 or 80-90 are fine, it's not terribly critical.
If you have 2" of play in the pedal that's more than enough to ensure suspension travel isn't binding things up.
