If oem optional floorboards are installed on a Volusia is it necessary to change to a heel/toe shifter? How difficult will shifting be with stock toe shifter?
k9,
The shift rod is adjustable. Therefore you can raise the shifter up high enough to get your foot between the shifter and floorboard...to up shift. I hardly use my heel shifter because I am lazy and don't like to move my foot.
don't know about the install . However heel and toe (H/T) shift is simple as stomping your foot!
Hard tap the the toe to down shift and stomp your heel to up shift .
A regular tap dance!
Wouldn't want a cruiser w/o a H/T shifter.
If you have big feet (12 and up)tho you might have a time placing your foot between the the 2 ends
I have Cobra boards on my 03. I do not have a H/T shifter and I did NOT have to adjust my shifter at all. I have a 10.5 shoe and have absolutely no problems shifting. I took a bit to get used to, but now I don't even notice it.
