I changed both my front and rear tires today and the front brake pads (and oil change). Took the wheels off and had the dealership mount the new tires. After i got it all buttoned back up i took it it for a very short test ride.
The bike seems slightly harder to move and i hear a slightly louder "hiss" from the front pads rubbing some. I assume this will go away once they're bedded?
Also, on the test ride there was a weird noise, kinda of a knocking/clanking from the rearend somewhere. The noise would seem to stop when i pulled in the clutch. When i put the rear wheel back on everything seemed to line up fine. I'm not sure what the problem could be. Any ideas?
The only thing that didn't seem right going back together was the brake drum stabilizing bolt. When i tightened it down the nut hit non-threaded part of the bolt before it the two pieces were tight so the bolt spins easily. I can't see this being the problem though because that just keeps the brake drum from moving which it should still do.
