1 - 13 of 13 Posts
Hi All!
To those who removed the entire assembly: How did you get to the bolts on the front jug? Did you have to remove the radiator and/or gas tank?
Thanks,
Dave
Did not have to remove the gas tank or radiator. I loosened the bolts to the radiator and removed the horn put a soft handled screw driver between the radiator and frame. Was enough room then to get to the front tube. Hope this helps.
On the other hand, some of us have larger hands. I had to pull the top hose off the radiator and pull the radiator forward. I lost a little coolant. Be sure you don't let pets get at that spillage -- it'll kill them.
I loosened the radiator and would stick my left hand inbetween the radiator and frame to apply pressure to keep the wrench on the bolt with my fingers. I used my right hand to work the wrench and was able to slowly, painfully, get about a 16th of a turn 85 million times to get it off. It - along with adjusting the valves - was the biggest pain to get to. I wish I had thought of the soft handed screwdriver between the radiator and frame - DUH! Doing the valves soon and I am so happy that the all the pair crap is gone!!! :D
EDIT: I didn't remove the horn assembly, I only disconnected it and loosened it and pushed it out of the way so that I didn't have to fight the bracket/bolt for reinstall... I am happy I did that.
I was alone at home and at one time I actually got my right hand STUCK :shock: between the frame and front jug for about 3 minutes. I really could not get my hand out and was thinking to myself... how STUPID will I look having to destroy my bike to get my hand out. I managed to wet my hand and it slipped out... still have the marks from the small cuts on my hands as I type... be careful not to do the same. Small hands, I have them... but, they just weren't small enough. Should have waited for my 9 yr. old daughter to help.
Good luck!
NJ10
8 year old daughter had tiny little hands that could turn the screw once I loosened it. :wink:
Jim
Thanks for all the good tips :!: I'm just curious about the soft handled screwdriver... is it the "weapon of choice" because it prevents scratching something or just a better grip?
i removed the horn and tossed it. it is pathetic sounding. if i really need to get attention, i figure i can scream real friggin loud. lots of room to remove bolts without horn in way
I just installed my second Mocc's kit on a friends bike. This time he brought a driver with about a 4-5 inch flex drive attached to an 8mm socket... what a difference. Put the flex in between the loosened radiator and the frame and put the flex on the bolts... no more 85 million 1/645000ths of an inch turns!. You just have to break them loose with the wrench. On re-assembly, just start the new bolts from Mocc's kit and use the flex to snug them.
A side note... what in the world is Suzuki thinking with that huge 12mm bolt holding the horn bracket. Mine was easy to break, but on my buddies - I had to use a cheater bar! Man was it tight.
Get a flex drive... I've done it both ways and its worth it.
NJ10
Discussion Starter #10
NJ10
Will have to get myself a flex drive...thanks for the tip :D
...Ummm...isnt 5/16 close to 8 mm?? I loosened the lower radiator bolts and took out the upper . Been a while since I have done it .. I believe the MC crash bar got in the way a bit too. .. The bolts that come with mocs kit are nice , I reused the chrome ones that were on the pair pipes , personal preference. .. So perhaps you can break the bolts free using an 8mm wrench and then you might have the flex drives , universal joints , small hands , whatever in 5/16 for your disposal ..
1 - 13 of 13 Posts
