Good evening guys! I'm having an issue with my bike (2003 VL1500 LC) and I'm hoping that you may be able to help me out. I'm getting power when I turn on the key, the "N" and oil lights come up but nothing else on the dash. No fuel gauge, no odometer, nothing. Tail lights and turn signals work, but no turn signal indicator on the dash, just blinkers working. No horn, no start.
Recent changes:
I added 14" apes and I'm in the process of putting everything back together from that. I added 10" of wire for each circuit in the handlebars, one at a time with solder and shrink wrap. I tested each one after I pulled them through and they are all done right. I had it all running until I tried to install the throttle side control box with the kill switch in it. I killed it and then installed that box and the throttle. I did pinch the wires a little but I took it all back apart and have checked the continuity for each wire inside the control box all the way to the plug and they are all good. Also I checked resistance of those wires from the box to the harness plug as well as continuity from the wires to the bars to make sure I didn't skin a wire when pulling them and that's good too, no shorts.
I have 12.3 volts at the battery and at the ignition switch. The main fuse is good. I'm going to put a charger on it anyway, but I don't think that is the issue. I checked all of the fuses in the right side fuse box and they are all good. I'm kind of at a loss right now on where to look next. It seems like it has to be a fuse but they are all good. Am I missing a fuse or circuit breaker somewhere?
Any insight or help would be appreciated!
Thanks!
Justin
Recent changes:
Thanks!
Justin
