21 - 24 of 24 Posts
Discussion Starter #21
Ok well it's not in the radiator, it's not around the thermostat. The water pump impeller won't rotate. I presume that's normal? I filled up the coolant. Warned her up. Cooled her down and started her again to find the radiator leaking through the fins. Maybe I damaged it or it may have already been damaged who knows. I'm going to use some Kseal to hopefully seal it.
Discussion Starter #24
New radiator arrives today. Easy enough to get the pipes disconnected but how do you get the plug at the bottom of the radiator off? Can't see any tabs. Or does it unscrew?
21 - 24 of 24 Posts
