1 - 1 of 1 Posts
I'm fixing the engine on my 2001 VL800. the Haynes manual tells what bearings to use with each rod and crank number code. The problem is when I'm all said and done the crank won't be the same number codes as what is stamped onto it.
Does anyone have the actual dimensions for:
Crank journal 1
Crank journal 2
Bearing color green
". " black
" " brown
" " yellow
" " blue
I'd like to avoid ordering 2 sets of each bearing color.
Both of my conn rods are code 2 so there's no need to look those up. But if you have the dimensions for rod 1 and 2 that may be a good resource to have for later or other weirdos like me.
Thank you
1 - 1 of 1 Posts
