Bought my C50 k9 model NEW in 2010 & have a little over 30,000 mi. on it. Finally developed my 1st problem. I've got a "little" oil leak that appears to be seeping from my side stand safety switch. Is there an O-ring under that switch that may need servicing? I can't find an breakdown image of the thing anywhere. Any thoughts on this Would be appreciated, Thanks in advance for any guidance in this matter. R.Tillery
OHKRAPP! Yup, parked next to an old sportster last week, didn't know "harleyism" was contagious..."live & learn" I s'poze. Thanks for the image breakdown, I see there's an o-ring as well as an oil "cap" that are likely culprits to the seepage. I'll change out the o-ring as a starting point. Thanks Again, R.Tillery
Greetings from Canada I had a 2005 and 2009 C50 and neither had a leak there. My 05 had some timing chain issues and was apart a couple times and a slight seep developed near the front where the two cases joined together.
So far it doesn't look like any have had that problem. I thought the switch was an externally mounted device. I would guess that you have a gasket seeping above the switch and it looks like it is coming from there.
Something I heard of is clean off the area and then dust it with baby powder to help you discover where the source of the leak is.
welcome from Ct...hope others can help lead you to a fix. good luck.
Related Threads
Suzuki Volusia Forum
2.5M posts
33.5K members
Since 2002
A forum community dedicated to Suzuki Volusia and Boulevard C50 motorcycle owners and enthusiasts. Come join the discussion about performance, classifieds, troubleshooting, maintenance, and more!
