1 - 2 of 2 Posts
i just purchase a set of double headlight for my 05 m50. In the stock headlight theres is a bunch of rolled up cable. where do i put does cable when i put on my double headlight?
I pulled them in and tucked them under the tank. You'll have to re-wire/extend some of the cables in order to do that. Nothing that wiring and soldering wont fix. Get a solder and some head wraps and youre gold. Use the solder's hot tube to shrink the wiring tubes... don't even need heat gun.
1 - 2 of 2 Posts
