1 - 12 of 12 Posts
I had a fleece blanket accidentally fall on my pipes after riding and heat from the pipes burned the fleece right on to the pipes and messed up the chrome. I wondering if I can take the pipes off and get them cleaned ( probably have to sand them down ) and re-chromed.
Anybody had any experience refinishing their exhaust pipes that you can share some things that might create concern?
Try cleaning the spot with easy off oven cleaner. You prob have melted plastic on the chrome and the pipes are prob fine.
Ride Safe,
Rex
Yes I've used easy-off..... Get the pipes warm not super hot but warm enough you can't touch them. Carefully spray the easy-0off on the pipes (or a cotton rag) and let it sit for a while. I used cardboard to protect the paint on the bike from overspray. I don't think it would hurt the piaint but didn't want to find out.
Oh... and welcome to the site.....
The Volusianator said:
I'd use an angle grinder! :lol:
lmao
By the way bglen... just in case... not that you would.... dont do this.
Thanks for the responses
I think I'll stick with the oven cleaner approach, I never thought of that. As for the "angle grinder", I see that even this forum has some who really don't care about constructive advise, but you'll have that.
bglen,
if that doesn't work (if vOluia says it might then there's a good chance it will) and you decide to rechrome or ceramic coat your pipes, then I would consult wildman because he has done allot of research on the topic.
good luck
Also with a light oil (wd40, 3 in 1) and 0000 steel wool a lot of stuff will come off without scratching your chrome. Also Bule Job works ok.
Ride Safe,
Rex
Re: Thanks for the responses
There is also those with out a sense of humor but you'll have that too :D :D
See doesn't smily faces make it all better.
CG
1 - 12 of 12 Posts
