personally I would travel the 3 hours if the mc is worth considering...when I bought my used c90 I was headed to a mc dealer specializing in all types of used mc's 3 hours away...Pembroke, NH, to replace a c90 I had just lost in an accident...on the way there I stopped to check out a c90 I found listed privately 90 minutes from home and the minute I saw it I knew as long as it started and had no issues I was not going to NH...mc had 8k on the dial,,,now over 80k without any major issues.
Discussion Starter · #6 ·
I have seen some nice bikes in Pensacola and Jacksonville which are both 4 hours away but it probably would be worth it to make the drive to get what I like rather than take whatever shows up locally.
Thanks
I've had some luck using searchtempest.com
Plug in the model in motorcycles/scooters and mileage radius and it will search craigslist listings in cities within that range.
It's handy for checking prices on that model in your area too.
I've had some luck using searchtempest.com Plug in the model in motorcycles/scooters and mileage radius and it will search craigslist listings in cities within that range. It's handy for checking prices on that model in your area too.
I'm live franklin n.c I have 2008 c90t around 20,000 miles, has not been on the road for about 2 years.Only problem by not riding only starting and run it for a while the clutch slave cylinder will not engage the gears. It is simple fix from what I have read. If you have interest you can reply buy e-mail.
