1 - 1 of 1 Posts
Idk if someone has posted something similar but figured I'd share regardless. I replaced the original turn signals on my 02 VL800.
The back left signal busted when I first loaded her on the trailer last spring. I used some silicone, jb plastic weld, and some metallic paint. Worked fine and was sturdy until my sisters bicycle fell and smacked it last week. Tried some more jb weld but the little sucker wasn't having it. Didn't want to spend a ton of $ on an oem replacement so I decided it was time to go led.
145286
They blink inside to outside. Look pretty nice when in operation.
145287
All taped up and zip tied.
145288
Fronts:
145289
145291
145292
Here I capped off the running wires.
The signal works on its own as well as the running light. The running light is always on (when key is turned). When I click the signal, the running light doesn't switch off to allow the blinker to show. Not sure how to fix it or of it's the new relay I got? Idk
145293
Just going to use them as signal lights for now
1 - 1 of 1 Posts
