So, lately, I have had to play with my key a bit to make a connection. So I figure my ignition switch is going bad. Is there a way to get a new one and keep the same key?
The switch on my 2005 C50 went 2 months after my 5 year warranty ran out at 56,000 miles. With what I had to go thru replacing it and having 2 keys I swore I would replace the next one with a toggle switch. As long as you can lock the front wheel it can only go in circles.
Discussion Starter · #5 ·
So, the self fix doesn't work... My switch is held together with brass rivets instead of the torx screws. So any ideas from there? I would much rather not have to spend $150-$300 for a new one or set.
Discussion Starter · #6 ·
will an 05 ignition switch work for an 01?
I have no idea on the 05 working on the 01, but have you talked to a locksmith? A good one might be able to fix the one you've got for cheaper than a new one.
Discussion Starter · #9 ·
I cannot open it without drilling into it.
