1 - 11 of 11 Posts
I will buy your spare bulbs...anytime. PM me.
You looking for just the replacement bulbs or the glass assembly out of the OEM lightbar lights?
light bulbs
After the first five went bad I switched to sealed beam tractor bulbs from NAPA. Strangely enough I haven't had one of these blow in over a year. So far thats a lot better than the junk that Suzuki is selling for bulbs in the stock light bar.
I did go riding with a buddy a few weeks ago and he bought ten of these because they were going bad so often. Replaced his first one for this season on our first ride of the season.
Re: light bulbs
I had4 seasons and 35,000 on the tractor bulbs before they were squished by a Ford
I did the same thing. Blew both the left and right bulbs after only a few days. :( Stealer replaced them free the first time.
Those blew out in a few days too! Suzuki bulbs are crap! :x
Tried Honda bulbs which some had success with and one melted the connector. I caught it before it caused any further damage! Tossed the Honda bulbs! :evil:
Finally chnaged to sealed beam 4411's in mid 2002 and have not had one go out since. :wayhappy:
I'm still using the factory Suzi bulbs, after a year and a half. :?
Honda BULBS last forever... Suzuki bulbs suck!
No soldering required, install just like the Suzuki bulbs
Honda bulb # is 34901-MN1-671.
No soldering required with the sealed tractor beams 4411's either.
strip the wire & bulb connector off from inside the stock light bucket and wrap the wires around the screws on the back of the 4411's. granted, it would be BEST to solder...but if not available, just be sure to secure all wires behind those screws ;)
yeah...suz bulbs suck. altho the ones i had only blew each side once, and thats all it took to go to the 4411 at the end of 2006 season. haven't had a lick of trouble since.
Save your money and put the 4411's on. It takes about $20 for the two bulbs and half an hour of time and you're done. No worries or blown bulb in the 12K on the 4411's.
A better, safer way would be to install ring terminals on the ends of the leads. You're asking for trouble if you just wrap the wire around the screws.
1 - 11 of 11 Posts
