· Registered
I’ve been doing research all night and can’t find help so hopefully here I will do
I removed my rear fender and bought a led combo light (stop,running,turns)
But it comes with 5 wires
I have the stock pony still
Can I just wire the 5 wires into the existing pony?
Because I know ;
Brown---running light
Black with White stripe---ground
Black---left turn
Light Green---right turn
White Wire with Black stripe---brake light
thank you all advice is appropriated
Ride safe
· Super Moderator
Welcome from Kennesaw GA!
You should be able to. Unless the instructions say otherwise, I don't believe you'd need to add anything in. Can't remember how many wires are on the stock connector, but if it's only four, you likely just need to run the ground to the frame. You should be able to find a wiring diagram for the bike on here somewhere. If not, a bit of patience and a multimeter should tell you which wires are which.
· Registered
One thing to be concerned with is the flasher relay may or may not work with the aftermarket LED bulbs. That will prevent your turn signals and emergency flashers from operating correctly.
· Registered
Because I know ;
Black---left turn
Ride safe
What LED combo did you purchase?
