1 - 2 of 2 Posts
My 2002 Volusia suddenly started idling very fast. If I cycle the choke on and off the idle will return to normal, until I add throttle again. Anyone heard of one like this? 35000 miles, never had any problems. Please help!
Sounds like a vacuum leak. Wave an unlit torch or spray carb cleaner around the carb boot and intake with it idling. If the RPM suddenly jumps up you found the leak.
The Vol's also have vacuum lines running to the tank petcock and fuel pump, which after nearly 20 years, may have perished.
1 - 2 of 2 Posts
