1 - 10 of 10 Posts
About a month ago I went out to try and fire up the bike and it turned over, idled for about a minute or two on full choke and then died. I tried to get it started again after that but couldn't. I thought maybe it was due to it being so bitter cold. So this weekend being as it was in the 50s I went out to try it again and the same thing; full choke and it idled for about a minute or two and died. This time I tried to start it again giving it some gas and I got it to start but if I let off the gas at all it sounded like it was going to die again. If I stayed on the gas some it would stay running. However, while I was doing this I noticed a wet spot forming under the bike, I let off the gas and it died. I checked the puddle and it was gas. I traced it back to it coming out of the breather tube that comes off the carburetor.
This past fall I had the carb all apart and cleaned and jetted it. I rode it until it got too cold and it was fine. What happened? Any suggestions? Thanks in advance!
2001 VL800
Mine was doing that with a dirty pilot jet, I didn't have the leak.
how long sitting? Ethanol gas?? Jack would not effect unless at some extreme angle. With gas dripping I'll go with the stuck float.
A stuck float would cause that carb to flood ,causing that cylinder to run rich,to the point of not running,,,,
how long sitting? Ethanol gas?? Jack would not effect unless at some extreme angle. With gas dripping i'll go with the stuck float.
ditto !!
1 - 10 of 10 Posts
