1 - 2 of 2 Posts
Debaffled stock pipes: 45 pilot, 140 main. Add two shims to existing shim(total 3), on bottom side of stock needle. Mixture screw 2.5 turns. Be sure to plug secondary air port as per Thunder. It is under the round intake (venturi) housing. Be cautious, as this is held in by two brass screws that have been blue loctite in by the factory
Call Robert at 770-974-8851 or at http://www.motorcyclecarbs.com/
He is a great help if you get in a bind!
Mike
1 - 2 of 2 Posts
