Hey guys, I'm in need of some help. does anyone know how to remove the key set from the ignition cylinder on a 06 C50T. I have the front cover off and the whole switch assembly off the bike but can not figure how to remove key set from the switch to make a new key.
Thanks Russ
Any locksmith should be able to do it if you take the whole thing in to him. Why not take the lock from the left side cover, it's the same key?
Although it's the same key, the ignition has a couple of extra pins in it. A key made from the side cover or even the gas cap will not work in the ignition.
I'd have to do a search, but there used to be a guy that could supply a key based on the serial number on the ignition if legible. He might be out of business now - not sure.
