1 - 11 of 11 Posts
I put kong bars on. Extended my ignition switch wires. Now it wont turn over. I have triple checked the wires are connected correctly. Is there a fuse that i could have possibly blown? It ran great befor i cut the wires
Check the fuses
I checked fuses under seat and the ones behind the primary cover. All looked good
Sometimes looks can be deceiving, I’ve been fooled enough times by fuses that look good that now I check them with my multi meter to be 100% sure they are good.
Then we are past my knowledge now. Hopefully somebody with more knowledge and expertise then I have will come along soon and be able to help you.
Im going to check wires from the connector to switch with multi meter. Making sure i dont have a bad wire or connection
I fixed the problem. I had a faulty wire in the new wire loom. All is good
1 - 11 of 11 Posts
