I got a set of HD Risers from VR member.
Question I have is if a washer is needed for the top part on top of the triple tree cover?
Stock riser had a washer. Instructions said that I would reuse the rubber washer, which I did underneath the triple tree.
Problem I see is the HD riser are not flush on the triple tree. Which looks ok, but the risers have some play. I can move them forward and back.
Is this normal? Stock riser did not have any play.
Should I add washer on the top of triple tree?
