I am looking for hard saddlebag mount recommendations for a 2013 C50. Also, when installing, is it preferred to drill larger holes in the sides of the saddlebags and use rubber grommets?
What sort of bags are you mounting....ie, cheapies or Tsukayu'ish style?
Those bags look similar to Tsukayu.....are they plastic or fiberglass?
Tsukayu's are fiberglass, and I used the Tsukayu factory mounts, heavy stainless steel, and large fender washers to aid support.
Some pics below:
Automotive parking light Automotive lighting Automotive tire Grille Hood
Car Motor vehicle Vehicle Automotive lighting Hood
I'll suggest Easy Brackets. I had a set on my C50 and was very pleased with them.
I'm sure you would have to drill the ABS of your bags very carefully, and reinforce around the holes with wide washers. But the Easy Brackets I had were useful and good quality.
