I don't know if wire would be a good choice :D:eek:
02 volusia, 33k miles, straight pipes w/full heat shields, all stock, white with 1/2 the chrome blacked..
I'll take a shot...
You can install "wider" handlebars usually without changing cables. Stock is ~34" so you could possible go 35~36" without a problem.
If you want to go "taller", then 12" is probably the max on the older 2001~2005 which had longer cables. Maybe have to reroute the throttle cables behind the top of the fork (triple tree).
The newer C50s have much shorter cables so 12" is probably too tall, 10" is max with the bars pushed forward. You probably need new cables if you want 12" on a newer bike.
I'm buying Hendel Bar Size 16in
Should I buy Cablel taller than the original?
Can I get a cable for my bike sazuki c50t 2013
thanks
