I am going to buy some stainless braided line cover to do my clutch and throttle cables (brake line already is braided). After I run the covers on the lines...I am going to put PVC clear heatshrink over them. This will provided the same look as the brake line ( hope!) and keep the cover tight on the lines. I emailed http://www.buyheatshrink.com and they said my idea was spot on...they suggested PVC because it will not fade or color in the sun, and it is crystal clear. So..if this works...here is a big money saver!!! I found the stainless braided line at http://www.cableorganizer.com/stainless-steel-braid
At the termination points at the throttle side...I will put a small section of black heat shrink to make it look purty. I will use the rubber boot on the clutch side.
I am only running the braid from the grips to under the tripple tree, I feel going all the way to the case and carbs is a waste.
