Hey everyone, I was wondering if someone knows if SAE 90 is the same as 75w 90? I want to change my gear oil an the owners manual states SAE90. So before I do anything I want to make sure I'm using the right stuff. Any help would be great thanx.
Thanx I rather be safe then sorry. Mine is an 08 and I don't want anything to wrong with her.
75w90 is actually superior to the 90 called for in the book. It is more than likely a synthetic that will reduce friction and heat in the drive. The "Dino" -non synthetic viscosity gear oil would be "80w90". That would also work with NO problems.
I use Royal Purple SAE 75-90 you don't change the gear oil very often so I don't mind paying a little more for the gear oil.
I like Royal Purple because the transfer case, tranny and axles of my Suzuki Samurai were made significantly quieter when I switched to Royal Purple SAE 75-90. :wayhappy:
