I have a 05 M50 boulevard with 4500 recently installed a new fuel pump everything lights up fuel pump primes an the bike will crank but wont start makes buzzing noise unless kill switch Is engaged not sure if that's normal but any suggestions seems to be getting fuel but wont even try to start I'm thinking spark as it has sit prolly a year
Welcome from Kennesaw GA!
That buzzing noise is probably the fuel pump engaging. Have you pulled the plugs to see what they look like yet? Probably wouldn't be a bad idea to change them. Wouldn't hurt at least. The state of the plugs can tell you a lot about an engine.
Thanks I will check the plugs I just got the bike an the guy said fuel pump so i inspected that an found it was busted so ordered a new one and installed now just keeps cranking over with no attempt to start
Internal combustion engines need 3 things to run -- fuel, spark, compression. Your job is to figure out which one (or more) is missing. Good luck!
